Loading data to elastic search
  • Oct 16, 2017 1:57 PM UTC
  • 6 replies
  • 121 views
boubcher
Forum|alt.badge.img+11
we have a simple workspace MSsql spatial reader and elastic search writer, but we are having this error, attached text file
Any idea
mark2atsafe
Forum|alt.badge.img+59
What's the error? I only see two workspace files attached.
boubcher
  • Oct 17, 2017 3:28 PM UTC
ElasticSearch coordinates are always stored in LL-WGS84. If spatial data in a different coordinate system enters the ElasticSearch writer, then FME will try and reproject the data to LL84. In this case, it looks like the SQL Server reader is not returning a recognized coordinate system for the dbo.Parcels_View table. Use FME Data Inspector to view the dbo.Parcels_View table and confirm the source coordinate system. You might have to explicitly set the coordinate system on the SQL Server reader.
boubcher
  • Oct 22, 2017 2:52 PM UTC
@Mark
Thanks we fix the problem of the coordinate as you recomanded , but we are still unable to display the polygone on Kibana Dashborad
take a look at the print screens
https://qsnapnet.com/snaps/jb0alvm930kep14
https://qsnapnet.com/snaps/9nwed91dp7ujtt9
All snaps: https://qsnapnet.com/folders/v2r8vs0btwhr529
boubcher
  • Oct 25, 2017 4:21 PM UTC
@MarkAtSafe
Any idea ?
@Mark
@boubcher It looks like Kibana does not support geo_shape. I found this request for them to add support. There seems to be several requests for this here and here . You could add your thoughts to one of these discussions.
