Loading ArcGIS Pro Annotations which have Leading Line
ostoja
I am trying to load ArcGIS Pro Annotations which in the source system have also Leading Line. Annotations are successfully loaded into the FGDB, but, although I populated (hopefully correctly) all geodb_text_leader_line* attributes, Leading Lines are not visible.
Does anyone have maybe working example on how Annotations containing Leading Line should be loaded in ESRI GDB?
Be the first to reply!
