LineString to MultiLineString -> Postgis
  • March 28, 2013
  • 331 views
Hi there,
I'd like to insert data into a postgis datebase. The destination table is already created. Unfortunatly, the translation fails due to a geometry problem :
Bulk copy failed on table 'az.eu_collecteur' using delimiter ':'. Error was 'ERREUR: Geometry type (LineString) does not match column type (MultiLineString)
CONTEXT: COPY eu_collecteur, ligne 1, colonne geom : « 010200002015550000020000007B14AEC7C07C2041AE47E17ABE0403410681...'
How can I transforme my source data form LineString  to MultiLineString ?
Any ideas ?
thank's in adavance.
  • March 28, 2013
it could be lots of things, including a bug somewhere. Can you tell us a little more:
  • Which version of FME
  • Which version of PostGIS
  • A log file dump of the feature in question (send it to a Logger and copy-paste it here)
A screenshot of the feature in question would also be helpful.
David
  • March 28, 2013
One thing to try: Just before the writer, insert an AggregateFilter.
For the output port "Aggregate", send the features directly to the Writer.
For the output port "Not aggregate", send the features to a Counter and then an Aggregator with Group by on the counter attribute.
That should force all non-aggregate features into each their own aggregate.
Please tell us if that works.
David
dparsons42
Worked for me !! Thank You .. even 7 tears later !
