LineOnLineOverlayer after upgrade from FME 2020 to FME 2024 output there is a count difference in outputs. The data used for both version is same, In FME 2020 the tolerance parameter was none while there is no such option in 2024, so used 0 as tolerance value. Still showing count difference.
