LiDAR to RasterDEMGenerator
  • Apr 30, 2013 10:16 PM UTC
  • 129 views
Hi all,
Today is my second day with FME, so I apologize if my quesrtion is very basic.
I am trying to convert LiDAR (las) to DEM data (esri grid) but am having a problem with the interpolation. Any files that do not have adjacent las files to them - that is they are on the perimeter - interpolate all areas within their tile even if there is no data.
Is there a parameter that limits the distance for interpolation or somehting similar?
Thanks.
  • Apr 30, 2013 10:37 PM UTC
Please keep in mind that I do not have a project boundary etc. that can be used as a clipper. I'm wondering if this can be done without a clipper.
Thanks!
fmelizard
Forum|alt.badge.img+22
  • May 1, 2013 7:26 AM UTC
If you read the LAS file without the point cloud coerder, than you automatically get the bounding box of the features, this can be used as a clipper after interpolating the DEM.
Hope this helps.
btw which transformer are you using to create the DEM?
  • May 1, 2013 3:28 PM UTC
Hi Itay,
Thank you for your response. Currently I am using the "RasterDEMGenerator" to convert into grids.
