KML Snippets element for document maxlines
  • September 11, 2013
  • 16 views
Hello,
Apologies for the long winded subject.
Is it possible using a transformer to set <Snippet maxLines="2"></Snippet> just under the <Document> tag?
If I use AttributeSetter and set kml_snippet to maxLines="0" but in the resultant kml file I end up with <snippet>maxLines="0"</snippet> instead of what I want as <snippet maxlines = "0"> </snippet>
I am using  FME 2012 SP 2
Cheers,
Best answer by fmelizard
Have tried any XML transformers?
fmelizard
Forum|alt.badge.img+19
  • September 12, 2013
