JSON to flat table
  • December 19, 2019
  • 6 replies
  • 299 views
jasperwis
Forum|alt.badge.img+15
I am new to JSON and I am trying to convert a JSON to a flat FME table.
In the workbench attached, I found a way, but I was wondering if there is a more
simple way.
My second question is: is there a way to convert this to a flat table without knowing the object attribute keys?
Jasper
erik_jan
Forum|alt.badge.img+18
  • December 19, 2019
The first JsonFlattener transformer should give you all the available attributes.
But the attributes will not be visible until you expose them, using the "Attributes to Expose" option in the settings of the transformer. (And yes, that will require typing the attribute names as FME does not know at this point what the attributes will be).
Hope this helps.
  • December 19, 2019
I would use the regular JSON reader with this parameters setting.
jasperwis
  • December 19, 2019
Thank you both!
jasperwis
  • December 20, 2019
One new question. When I want to use this workbench with a new json file, which contains one extra attribute, is it possible to get this extra attribute added correctly?
I enabled the "Merge Feature Type" (dynamic workflow), but since the schema was allready defined by the first json, the extra attribute is not added.
  • December 21, 2019
The reader can read every attribute from any JSON document as long as its schema fits to the JSON Query you have set to the reader parameter (below), even if it contains extra attributes.
json["collection"][*]
The extra attributes could be read definitely. You can see them with the Feature Information window in FME Data Inspector if you send the features to Inspector and run the workspace. However, those attributes won't be exposed on the Workbench Canvas automatically. I think that's the situation you have observed.
A possible workaround is to use the AttributeExposer to manually expose all attributes that could be contained by JSON documents you need to handle.
jasperwis
  • December 23, 2019
Is there a way to get these extra attributes in the ouput, without
having an understanding of all possible attributes?
because it's possible that some of the future files will have slightly different
attribute names "attribute1" <> "attribute_1". So it could be hard to identify all
possible attributes to list in the Exposer.
