Hi everybody I desperately need some help!! Here is my problem... So far I've been able to generate a bunch of different networks from my water pipes. I've also been able to use a fanout to extract them all to multiple PDF files, based on their network ID. Now, I'm simply trying to add some PNG images (North arrow, logo, etc.) on each PDF files, without any success?! At this point I've tried many things, but I'm now running out of ideas...
As suggested on another thread (https://knowledge.safe.com/questions/2403/adding-a-logo-to-a-pdf-when-using-fanout.html) I was under the impression that by using a Cloner to get as many images as I had networks, then by using the PDFPageFormater to add the images to each PDF files or a RasterGeoreferencer to specify where I want the images to be located on the page, I would be able to achieve that but I couldn't figure out how... And speaking of the RasterGeoreferencer, I didn't find out how to use page units instead of real coordinates, is it even possible?!
Please, tell me that there is a nice and easy way to achieve that with FME! :) Thanks in advance for your time!!
