It is possible to run password-protected workbenches on the fme-server?
  • Apr 21, 2017 6:09 AM UTC
  • 7 replies
  • 130 views
The title says it all.
Directly you can not upload these workbenches. But maybe using the FMEServerJobsubmitter. The password is then passed using published-parameter. You could upload a dummy workbench with the same name and exchange these directly on the FME server against the password protected Workbench.
Or are there other tricks?
itay
Forum|alt.badge.img+19
  • Apr 21, 2017 6:15 AM UTC
My guess will be yes (never tried it myself) since password protecting the ws is mainly intended for the desktop environment.
itay
  • Apr 21, 2017 6:46 AM UTC
Now its verified, it is possible.
  • Apr 21, 2017 7:11 AM UTC
Yes, I've been doing this since at least FME Server 2014, no problem.
You do not need to pass the password for the workbench to FME Server, it will know how to decrypt it internally for execution. Which of course also implies that the password protection of workspaces isn't super secure, but at least that's documented.
  • Apr 21, 2017 8:57 AM UTC
Thanks for the answers. I have not mentioned that corresponding password is unknown. Previously, the workbench was run only from the console (No password is required). Is it possible to use the workbench e.g. with a SystemCaller on the server?
  • Apr 21, 2017 9:02 AM UTC
Should be doable, yes. FME does not need to be supplied the password for the workbench to run it. Using the SystemCaller is a pretty non-standard way of executing workspaces on FME Server, however.
zzupljanin
Forum|alt.badge.img+5
  • Apr 21, 2017 1:58 PM UTC
What about REST API? I think the same rules should be applicable. Correct me if I'm wrong...
  • Apr 21, 2017 2:01 PM UTC
It should absolutely be possible to submit a job using the REST API even if the workspace file is password protected. Do you get an error?
