It is creating a Multipoint feature class instead of point feature class.
  • Mar 13, 2020 4:25 PM UTC
  • 176 views
Feature Writer : ESRI Geo Database(file Geodatabase)
Even though I have selected GEODB_POINT as Geometry in feature writer parameters.Tried to convert in to point using vertex creator but no luck.Can anyone help me how to write point feature class instead of multipoint.
daveatsafe
Forum|alt.badge.img+24
  • Mar 13, 2020 6:32 PM UTC
Hi @sindhugandu,
Please try using the Deaggregator to break up the multipoint before writing to Geodatabase.
@sindhugandu I can't reproduce your issue. As @daveatsafe suggests, try deaggregating your points. FME will report a warning if you try ad load multipoints into a feature type configured for point geometry:
WARN |The feature class 'CSV_multipoint' will be created to store multipoint features rather than point features, since the first feature destined for this feature class is a multipoint
See the attached example (2019.2): multipoint.fmwt
