Issues updating AGOL data from shapefile
  • May 7, 2024 9:05 PM UTC
  • 112 views
cdog
Hi, I am new to FME so might be making a rookie mistake. But I am trying to update AGOL from a GDB shapefile but it won’t update in AGOL. I have managed to get everything to work and it shows the updates but its not sending the data to AGOL. What am i missing here?
nielsgerrits
Forum|alt.badge.img+67
How is the FeatureJoiner configured? Because that does not join anything.
cdog
  • May 8, 2024 6:16 PM UTC
That might be my problem, I don’t know how to set it up correctly. Currently it looks like this:
Which is probably wrong.
hkingsbury
Forum|alt.badge.img+73
  • May 8, 2024 9:55 PM UTC
That feature joiner seems redundant in your process. basically its saying if objectid = db_op combine these features. Object ID will be numeric and fme_db_op will be one of ‘DELETE|UPDATE|INSERT’
You should just be able to pass the features from the inserted port straight to your writer. Make sure that your writer is set to:
  • Feature Operation: Insert
    • Can also use the fme_db_operation feature
  • Table Handling: Use Existing or Create If Needed
