I'm using the Esri Geodatabase (ArcSDE Geodb) reader with Feature Read Mode set to Metadata, to read in GEMINI metadata from SDE. I'd like to manipulate certain elements before sending the updated metadata back to the SDE feature class.
Using the XMLUpdater I've been able to amend the content for some elements, however I haven't had any success when trying to amend the revision date, as there are three different date strings all with the same XML path:
metadata/gmd:GEMINI_Metadata/gmd:identificationInfo/gmd:MD_DataIdentification/gmd:citation/gmd:CI_Citation/gmd:date/md:CI_Date/gmd:date/gco:Date
Currently none of them are getting updated on the output XML.
The different date types are differentiated in the gmd:dateType element, e.g:
<gmd:dateType> <gmd:CI_DateTypeCode codeList="http://standards.iso.org/ittf/PubliclyAvailableStandards/ISO_19139_Schemas/resources/Codelist/gmxCodelists.xml#CI_DateTypeCode" codeListValue="revision">Revision</gmd:CI_DateTypeCode> </gmd:dateType>
Has any tried this before, or has any ideas for how to just update one of the dates?
