is there a way to have the same number of output files as input?
  • Nov 11, 2019 4:00 PM UTC
  • 70 views
Hello,
I am new to this software, i have a bunch of KML Files that i have been successfully been able to edit. However when i go to run the software it combines them into the same file, is there a way to have the same number of output files as input? i.e. save individually not combine them
jdh
Forum|alt.badge.img+41
  • Nov 11, 2019 4:03 PM UTC
akipin
  • Feb 10, 2020 1:27 PM UTC
If you are using any transformer that has a Group By option, you can set it to group by fme_dataset.
I did this in the HullAccumulator to aggregate the 237 kml elements from 6 kml files back into 6 features based on their original kml source file (see attached screenshot).
