Is there a way to generate multiple Excel workbook using only one Writer?
  • Sep 13, 2019 4:01 PM UTC
  • 81 views
I have to generate approximatively 850 Excel workbook and I was wondering if it was possible using only one Writer or if I had to use 850 Writers.
I thought of the possibility of generating 850 sheets in one Excel workbook, but I would have trouble actually opening the workbook with my computer (lot of memory used).
Also I work with a 2017 version of FME (I stumbled in the past on issue that could be esaily resolved with 2018, but I had to work in the limit of 2017).
Thanks
Best answer by david_r
Have a look at the fanout functionality in FME, it will allow you to split the output over several files depending on a criteria that you can define.
https://docs.safe.com/fme/html/FME_Desktop_Documentation/FME_Workbench/Workbench/Setting_Dataset_Fanout_Properties.htm
https://knowledge.safe.com/articles/565/fanout-1.html
  • Sep 13, 2019 4:09 PM UTC
