Is it possible to write a .dgn level with just tags and no geometry with the Bentley MicroStation Design v8 Writer (while writing the geometry separately in another level, but to the same file)?
  • Oct 16, 2017 1:23 PM UTC
  • 5 replies
  • 92 views
thomas_merkus
I was wondering if this is at all possible?
danilo_fme
Forum|alt.badge.img+58
  • Oct 16, 2017 1:37 PM UTC
Hi @thomas_merkus,
Yes, is possible. I create a example to read a shapefile polygons and creator ( for example ) attributes ( tags ).
After, i did hold the polygon and text using the transformer FeatureHolder.
At end, i filter Area and Text ( GeometryFilter ) and add a Writer DGN V8 for Tags:
I duplicate the this FeatureType to Polygons. Rigth botton -> Duplicate
An Navigator you can see just a Writer file, but with two FeatureTypes: Polygons and Tags:
Thanks,
Danilo
thomas_merkus
  • Oct 16, 2017 2:07 PM UTC
Hi @thomas_merkus,
Thanks,
Danilo
@danilo_inovacaoThanks, can you perhabs share your example? It seems to work but when I open the result ouotside FME I don't get the tagset.
danilo_fme
  • Oct 16, 2017 2:11 PM UTC
Yes @thomas_merkus. I send you the Workspace template. Please execute and try to open my output.
Thanks, - -workspace-know.fmwt
Danilo
thomas_merkus
  • Oct 16, 2017 3:04 PM UTC
Hi @thomas_merkus,
Thanks,
Danilo
@danilo_inovacao Your example is a workaround for what I actually mean, but its very useful nonetheless Thx!. When you do it like this, the text becomes text-geometry. What I was wondering, if it's also possible to only write tags to a level with no geometr.
danilo_fme
  • Oct 17, 2017 12:38 PM UTC
Hi @thomas_merkus, Perfect.
I believe to create a geometry with tags.
Thanks,
Danilo
