Is it possible to use the '$' ASCII character on the OGC Geopackage field names?
  • Nov 9, 2020 1:02 PM UTC
  • 89 views
I need to use the ASCII 36 ($) character in the name of attributes on a geopackage file. In the direct way is it impossible, because the Use Attribute pane of the Feature Writer for geopackage changes the '$' char into a '_'; same story using an opportune schema in 'Dynamic Schema Definition'.
Is this a FME bug? Is there a way to workaround this issue?
@nicolap​ At the moment there is no straight forward workaround. @david_r​  gave a temporary workaround in an answer at the very end of this discussion. Please vote on the Idea and add any comments on your use case.
  • Nov 10, 2020 6:51 AM UTC
My case involves the writer so the suggested idea can not be applied. For the moment I solved manually renaming the attribute names in the geopackage.
