Is it possible to download/read an excel file from Sharepoint?
  • Oct 30, 2019 11:48 AM UTC
  • 6 replies
  • 369 views
sam_tw
Forum|alt.badge.img+3
Is it possible to download/read an excel file from SharePoint?
I can read the contents of the site using the SharePoint list reader, but unsure if I can then actually read a spreadsheet stored there?
Thanks,
Sam
Best answer by sipsysigh
Hi @sam_tw,
Is the version of SharePoint, where the Excel file is located, Online or Server? If Online, then as far as I know, you can't connect using the Excel Reader as it requires SAML Authentication. If however it's SharePoint Server, then as @jdh has said, you should be okay. Select File From Web and Specify the URL to the SharePoint Site:
You should then have the option, as @jdh says, to Use Network Authentication and select NTLM as the Authentication Method.
Hope this helps.
Simon
jdh
Forum|alt.badge.img+41
  • Oct 30, 2019 12:51 PM UTC
I have successfully pointed an excel reader to a sharepoint file. It depends on the permissions.
sam_tw
  • Oct 30, 2019 2:54 PM UTC
I am the file owner so have permission to edit it. Does it require more than that?
jdh
  • Oct 30, 2019 3:02 PM UTC
On the excel reader, there should be a parameter called network authentication. In my setup, I used NTLM authentication.
sipsysigh
Forum|alt.badge.img+12
  • Oct 31, 2019 1:05 PM UTC
Hi @sam_tw,
Hope this helps.
Simon
sam_tw
  • Oct 31, 2019 1:34 PM UTC
Hi @sam_tw,
Hope this helps.
Simon
Ah it is the online version of Sharepoint which explains why it isn't working, but the Sharepoint list reader using SAML does. Thanks
fpakzat
  • Feb 6, 2020 9:24 PM UTC
Hi @sam_tw,
Hope this helps.
Simon
When I go "Select File from Web" -> "Specify URL": the link required seems to start with http: but my link start with https; and then if I put my link (the one with https) there, the transformer doesn't read anything. I did try to change to http but it doesn't work either.
what does this indicate?
