Is it possible in a dwg file to extract value from custom part in BLOCK_DYNAMIC with CAD Readers?
  • Mar 9, 2022 10:36 AM UTC
  • 131 views
bernarddinon
Participant
Hello,
We are drawing with Autocad. We want to use dynamic block with Custom part (Visibilité1 and Angle1 see PrintScreen 1).
With FMe Desktop, is-it possible to have these values in a fields/attribute ? Our objectifs is to import data in a GIS with the values of Visibility to define some objects.
Best Regards.
Bernard Dinon
Print Screen 1
DWG_BLOCK_DYNAMIC_VISIBILITE
Best answer by nielsgerrits
Yes you can 🙂
Using the Autodesk AutoCAD DWG/DXF reader, enable the "Read Dynamic Block Attributes" checkbox.
Autodesk AutoCAD DWG DXF ParametersThe values are being output to the list autocad_dynattr_list{} which you need to expose manually.
Thanks for providing the sample data.
nielsgerrits
Forum|alt.badge.img+67
  • Mar 9, 2022 10:54 AM UTC
Yes you can 🙂
bernarddinon
Participant
  • Participant
  • Mar 9, 2022 11:55 AM UTC
Yes you can 🙂
Thank for Your answer.
Actually we use FME 2019.1 on desktop and Server.
=> The options is not available (Print Screen 1)
Which version it's?
For now, we must migrate FME Server and Destkop for a newest version in the next month I Hope.
Best Regards
Print Screen 1
nielsgerrits
Which version it's?
Best Regards
Print Screen 1
My screenshot is from 2021.2.
bernarddinon
Participant
  • Participant
  • Mar 9, 2022 12:05 PM UTC
Which version it's?
Best Regards
Print Screen 1
Ok. Thank for your Help.
Best Regards
