is fme supprort to read Arcgis Pro file formats (like aprx, lyrx,mpkx,etc.,)
  • Sep 1, 2021 1:24 PM UTC
  • 471 views
swethabhupathi
Forum|alt.badge.img+5
i want to read an aprx or lyrx file in fme . is it possible?
danilo_fme
Forum|alt.badge.img+58
  • Sep 1, 2021 4:22 PM UTC
Hi @swethabhupathi​
There is a Idea to implement in the future, you can vote it:
https://community.safe.com/s/idea/0874Q000000TlLKQA0/detail
Thanks in Advance,
Danilo
andreaatsafe
Forum|alt.badge.img+17
Hi @swethabhupathi​ ,
It should be possible to use the Esri ArcGIS Layer Reader to read in lyrx files.
There is only a small caveat if you use FME 64-bit - when you attempt to select a dataset with the GUI (i.e. the triple ellipsis GUI button) you will receive the following error message: "Selecting layers is only available on 32-bit editions of FME because it requires an ESRI Desktop ArcObjects product to be installed and licensed."
To work around this using FME 64-bit you must supply the full path to the dataset of interest including the extension.
-Andrea
