Install Rhino Module for Pyhton.
  • Jan 3, 2023 9:06 AM UTC
  • 5 replies
  • 362 views
kidega
Forum|alt.badge.img+9
I wounder how I could manage to install the Rhino module for python (external package)? I have tried to look up info from:
https://docs.safe.com/fme/html/FME_Desktop_Documentation/FME_Desktop/Workbench/Installing-Python-Packages.htm
and:
https://community.safe.com/s/question/0D54Q000080haVOSAY/how-to-install-external-python-packages.
What I seem to manage to do is to install the module with the following command:
fme.exe python -m pip install rhino --target C:\\Users\\*\\*\\Documents\\FME\\Plugins\\Python\\python37
The module seem to be installed at the directory, but when I try to import it (import Rhino) using python caller I get the error msg:
|Python Exception <ModuleNotFoundError>: No module named 'Rhino'.
The Rhino module is a non-universal package and I have tried to verify python interpreter to both 3.7+ and 3.9+ when running pyhton caller. I am using FME v2022.1.2.0 64-bit.
When I used to command line it prints;
"INFORM: Using python interpreter **\\python39.dll".
"INFORM: Python version 3.9 loaded successfully".
Successfully installed rhino-0.0.5.
If I should download and use a seperate Pyhton interpreter, what interpreter version would you suggest?
Thanks alot!
  • Jan 3, 2023 9:23 AM UTC
Unless I've found the wrong Rhino package, the project hasn't been maintained since 2015: https://github.com/trendels/rhino
Rhino seems to require httplib, which was renamed to http.client in Python 3, and based on this I suspect that Rhino isn't compatible with Python 3.
kidega
  • Jan 3, 2023 9:36 AM UTC
Hi @david_r​ ,
Thanks for quick reply! Ah that might then be the issue. Thanks.
kidega
  • Jan 4, 2023 10:33 AM UTC
Hi @david_r​ ,
Hi @david_r​ ,
Do you know if the module rhino3dm module is working with a calling function in Pyhton 3 with FME?
  • Jan 5, 2023 8:58 AM UTC
Hi @david_r​ ,
Sorry, I do not have any experience with this package. But at least the github looks active, which is always a very good sign.
kidega
  • Jan 5, 2023 10:44 AM UTC
Hi @david_r​ ,
Thanks anyways for helping out clarifying things.
