Insert raster image into DWG generates error: 'Failed to write raster with raster reference '1', ignoring texture'
I'm using FME 2019.1 and would like to insert an image (raster) into an DWG-file. I cannot find any detailed description regarding this and my attempts all end in an error saying 'Failed to write raster with raster reference '1', ignoring texture'.
I'm using a reader to read either a GeoTIFF-, JPEG- or PNG-file and send it to an AutoCAD RealDWG writer without any transformations.
Could anyone please upload an example FME-file that does this?
Thanks for your help
Best answer by m_andren
Thanks for your reply,
I think the problem was that I used an old script fråm FME 2016 and just added the raster.
When I created a new script in FME 2019 it worked fine.
Thanks, Mattias
daraghatsafe
Hi @m_andren.
Sorry to hear that this is not working for you, I tried converting a .tif file to .dwg and it worked successfully. Have you tried it with other rasters?
I would suggest testing with another raster to see if the same error occurs. Also, could you attach the raster to the post?
Thanks, Daragh
  • June 2, 2020
Thanks, Mattias
