Insert GUID into a Geodatabase
  • Sep 20, 2019 9:30 AM UTC
  • 6 replies
  • 125 views
xtian79
Is there any transformer that help me to change from any of the python valid formats for GUIDs to the arcpy valid format to insert it in the geodatabase?
The valid formats from python are:
{00010203-0405-0607-0809-0a0b0c0d0e0f}
000102030405060708090a0b0c0d0e0f
{000102030405060708090a0b0c0d0e0f}
the valid format received by the geodatabase is:
thanks!!
Best answer by xtian79
Extending the answer from @david_r the proper implementation would be to generate the valid value with python:
import uuid
validGuid =  "{{{0}}}".format(str(uuid.UUID(cell_value)))
feature.setAttribute('VALID_GUID', validGuid)
  • Sep 20, 2019 9:45 AM UTC
If you have a GUID field in your Geodatabase writer, you can generate a value suitable for writing using Python e.g. like this:
import uuid
feature.setAttribute('MY_GUID', str(uuid.uuid4()))
The MY_GUID value will be on this format: '5a35172e-071f-4a33-b191-172a9b4b02ae'
If you need curly braces, replace the second line with this:
feature.setAttribute('MY_GUID', '{' + str(uuid.uuid4()) + '}')
xtian79
  • Sep 23, 2019 7:05 AM UTC
import uuid
@david_r thanks for your answer, but as I state in my question the allowed format received for the geodatabase must include curly braces.
  • Sep 23, 2019 7:17 AM UTC
Weird, I've never needed the curly braces when writing to either of the Geodatabase writers, but I've modified my answer with an option to include the braces, if needed.
xtian79
  • Sep 23, 2019 7:18 AM UTC
import uuid
xtian79
  • Sep 23, 2019 7:20 AM UTC
row = rows.newRow(); row.setValue("MyField", '00010203-0405-0607-0809-0a0b0c0d0e0f'); rows.insertRow(row)
Traceback (most recent call last):
  File "<string>", line 1, in <module>
  File "c:\program files\arcgis\pro\Resources\arcpy\arcpy\arcobjects\arcobjects.py", line 2440, in setValue
    return convertArcObjectToPythonObject(self._arc_object.SetValue(*gp_fixargs(args)))
RuntimeError: ERROR 999999: Something unexpected caused the tool to fail. Contact Esri Technical Support (http://esriurl.com/support) to Report a Bug, and refer to the error help for potential solutions or workarounds.
A general error when something is wrong with a Field. [Myfield]
  • Sep 23, 2019 7:36 AM UTC
Thanks for the info, somehow I didn't catch you were using arcpy, which explains why you need the curly braces.
