Input some text and output as polygons.
  • December 1, 2014
  • 188 views
I have a need to change some text so it is in the form of a polygon. I was looking at some functions with labellers and wondered if they can be output in a shapefile for example and be in polygonal form.
I have seen a function MapTextLabeller which seems to output polygonal text, but its a paid plugin. Are there alternative methods?
Thanks.
  • December 1, 2014
After creating a text geometry with the Labeller, you can use the TextStroker to transform the text into polygon.
Takashi
  • December 1, 2014
In addition to Takashi's advice, you could think of generalizing the boundaries of the resulting polygons afterwards. I experienced that the TextStroker converts the text to geometry well, but the lines appear a bit choppy. You could try to smoothe them with an algorithm from the Generalizer (e.g. NURBfit).
Kind regards
Thomas
