Importing spatial data into PostgreSQL
Hi all,
Does anyone know how to import spatial data into Postgre? It seems  the option Allowed Geometries is greyed out.
Thanks,
Darius
Best answer by david_r
Hi
The PostgreSQL database isn't spatially enabled unless you also install the PostGIS extension. You can then use the FME PostGIS reader/writer.
David
  • August 7, 2015
Hi
David
david_r wrote:
Hi
David
Hello @david_r
I'm looking into this issue right now. Can you elaborate a bit more of how to install the postGIS extension? I am not getting much info online...
nielsgerrits
Forum|alt.badge.img+55
fariyafarhad wrote:
Hello @david_r
Run the Stack Builder and choose the version you need under Spatial Extensions.
See this post on Stack Exchange.
More details can be found here.
  • November 16, 2017
fariyafarhad wrote:
Hello @david_r
This is the first hit if you google "install postgis extension":
http://postgis.net/install/
Follow the instructions under "Getting started", on the right hand side.
