images to postgresql bytea
  • January 20, 2016
  • 11 replies
  • 175 views
Hi everybody,
i have to import smal jpg-files (400-500 kb) with geometry into a postgis bytea column. the process is very slow. for example the time to import 40 images takes 10 minutes. the import with pglobeditor takes 2 seconds.
Please help what could be the cause.
Best answer by fmelizard
Slow writing of data as bytea with the PostGIS Writer is a known issue in FME. Development is working on improving it as PR# 57164.
Forum|alt.badge.img+5
  • January 20, 2016
Can you use the Postgis writer or Postgis Raster ? Can you share your logs ?
  • January 20, 2016
  • January 20, 2016
Your process drops an existing table 'flug.images'... and creates table 'flug.images'...
Check this step:
  1. Disable your index
  2. Create your table before the FME process.
  3. Start your process without drop/creation table flug.images
  • January 20, 2016
From the screenshot, looks like you are using the PostGIS write. Have you tried the PostGIS Raster writer [POSTGIS_RASTER] ?
  • January 20, 2016
I try the postgis writer for the points. the images are only attributes.
  • January 20, 2016
Check this step:
Now, i have killed the index. Drop and Creation was only in my demo. But there was no effect. have a look to the new logfile.
import-images-2-postgis-without-index.txt
  • January 21, 2016
hallo,
it is possible to reproduce the problem with your own postgis ?
fmelizard
Forum|alt.badge.img+21
  • May 17, 2016
hsamor
  • March 13, 2017
Hi Natalie, what is the current status on this bytea performance issue? @natalieatsafe
nic_ran
Forum|alt.badge.img+16
  • June 28, 2018
Hi @NatalieAtSafe, any further update on this? Has this now been resolved? Thanks.
nic_ran
  • June 28, 2018
Following an online chat with Xiaomeng @Safe this PR is slated to be fixed in FME 2019.0
