ImageFetcher on FME server
  • Sep 11, 2013 4:18 PM UTC
  • 114 views
Hi!
Im working on a PDF cartographic output application running on FME server.
Recnetly I encountered the workspace is not flawless as it used to be. It seems around 1/3 of all executions will result in error similar to:
PNG reader: Failed to open the dataset 'C:\\Users\\SAFME2~1\\AppData\\Local\\Temp\\ImageFetcher_21378914917511_5860'. Please ensure source data is valid and correct reader is selected
This is a Imagefetcher. Used to get a WMS - PNG-image.
Error is at 1.8 seconds, so it cant be a timeout.
Pasting the WMS URL in browser works fine.
Using the same imagefetchers and URL in other .fmw-files  on the server works fine.
Downloading and running the workspace on desktop with same identical settings as on the crash works fine.
Im out of ideas. Should I clean the server up somehow? Any input most welcome.
Thank you!
  • Sep 12, 2013 8:05 AM UTC
the first thing I would check would be that the user running the FME Server instance has sufficient rights on the harddisk.
Consider temporarily giving the user Administrator rights or running FME Server as a local Administrator on the server to see if the problem goes away. If it does go away, the error is most probably due to insufficient rights.
David
  • Sep 12, 2013 8:59 AM UTC
Hi David
It is runned by the guest account, and its working 2 of 3 times meaning there must be sufficient rights..
  • Sep 12, 2013 12:32 PM UTC
Problem solved. Caused ofcourse not by FME but by instable WMS-server..
