IFMEFeature with aggregated/multiple geometry
  • September 12, 2024
  • 59 views
pehrs
We have a reader plugin (c++) that should be able to set aggregated/ multiple geometry to an IFMEFeature.
For example:
We have only several IFMEGeometry objects. These IFMEGeometry objects should be set to an IFMEFeature. So that we have finally an IFMEFeature that consists of several different geometry objects/ parts.
                                                         IFMEFeature
IFMEGeometry_Part_1    IFMEGeometry_Part_2    ….      IFMEGeometry_Part_n
fme_type = fme_area
fme_geometry = fme_aggregate
fme_feature_type = DepthArea
How can we solve this?
bwn
Forum|alt.badge.img+26
Try GeometryRefiner.  This will convert homogenous Aggregate Geometries to Multis (as well as to simply polygons if possible).
pehrs
I guess GeometryRefiner is only available in FME Desktop Workbench.
But this issue has to be resolved programmatically (c++) in the reader plugin and not in FME Desktop.
evieatsafe
  • September 18, 2024
Hi @pehrs I talked with some colleagues and this is some of the advice they suggest:
  • if you are asking about how to get a bunch of individual IFMEGeometry objects into an IFMEAggregate.  Then
    IFMEAggregate* fme::IGeometryTools::createAggregate() const and IFMEAggregate::appendPart(IFMEGeometry* geometry) would help.
  • You would then need to put your aggregate onto a feature before calling the method
    virtual void fme::v1_1::IGeometryTools::createMultipleGeometryFromAggregate(IFMEFeature & feature) const which is exposed on the FMEObjects API rather than the Plugin API.
I hope this helps, let us know if you have any other questions.
pehrs
  • September 19, 2024
Thanks, issue is solved.
