IFC3DObject Transformation from Local to X,Y,Z!
  • Jun 13, 2024 8:42 AM UTC
  • 92 views
featuremichael
Forum|alt.badge.img+9
Hello FME members,
I have an IFC file with no coordinate information in the site feature.
it is a 3dObject of a parcel that is supposed to represent the surface - but it is just a (3dObject) flat surface with an extrusion of 1]
What I have done:
I have at least 4 coordinates to transform, I tried to use:
the 3daffinewarper, but the transformer showed me an
error [because the transformation from 0,0,0 to x,x,444.1 is coplanar - and I only have 4 known points that went from z:1 to z:443] (I also tried 0,0,1 to x,x,444.1, but it didn't work)
so I used the affinewraper to send the surface to the correct coordinate system)
that worked!
i need to know how to get the 3d object to the correct z value to display the surface (3d object) at the correct height.
I hope someone can help me.
Greetings Michael
Best answer by featuremichael
Got the Answer by myself one day later.The offsetter did the job. 😅
Sometime you cant see the forst because of to much trees 🤣
featuremichael
  • Jun 14, 2024 10:01 AM UTC
