IFC->Multipatch->I3S(3D object slpk) colour issue
  • Dec 8, 2021 4:02 AM UTC
  • 247 views
jackfanzhang
I have a workbench which converts IFC to ESRI Multipatch, the original colours in IFC are reserved very well in the output Multipatch (as inspected in ArcGIS Pro), however if I convert the multipatch to 3D object scene layer package, it seems the colours are gone. there are not many option for me to play in the I3S writer. I have checked the FME I3S factsheet which has mentioned Generic Color Support: No. Not sure if that's related, but any advice how to keep the colours of the output .slpk matches what's in the original IFC or multipatch? thanks
nampreetatsafe
Forum|alt.badge.img+14
Hi @Jack Zhang​, which version of FME are you using? This should be possible with FME 2021.1 +. If you're using an older version, you can use the ColorAppearanceReplacer (a custom transformer) to convert to an image texture before writing out to I3S. Hope this helps.
jackfanzhang
  • Dec 12, 2021 3:34 PM UTC
hi @nampreetatsafe​ , thanks for the reply. I'm using 2021.1, I'll try to get some screenshot later to explain what I mean. thanks
