IFC file problem - ISO10303-21: The input data file has a syntax error
  • Jun 27, 2023 12:55 PM UTC
  • 125 views
Hello,
I tried to make a workbench that write ifc from our data base (building).
When i try to read the final file, FME cannot because of syntax error for the ISO10303-21 format.
Each building has one ".." value that cause the problem.
#35=IFCBUILDING('O6Hu3fDbRB2OEJH5wcfNLw',#23,'51_102','','',#34,$,'51_102',..,$,$,$);
If i change the ".." by a $ (that mean 'Null' according to BuildingSmart) the file is fine and FME is ok to read it.
Does someone know what parameter or attribut I missed in my workbench that cause the ".." ?
Thanks !
daveatsafe
Forum|alt.badge.img+24
  • Jun 27, 2023 10:45 PM UTC
Hi @matthieubarth​,
Please check the workspace that creates the IFC file to ensure that the output IfcBuilding feature has the CompositionType attribute set to ELEMENT. I think it may be blank at present.
Hi @matthieubarth​,
It work ! Thank you :)
