Identifying MULTISURFACE and CURVEPOLYGON
  • Sep 24, 2025 12:43 AM UTC
  • 6 replies
  • 206 views
krio
Hi all.
I need to identify (and convert) multisurface /curve polygons in a GDB.
The GDBs contain one feature class with many polygons: some of these records are multipart polygons. The data I am working with comes from uncontrolled sources using different GIS programs, so the GDBs are put through a workbench to identify obvious spurious geometries like self-intersections (this works well). However, I am having a recurring problem where the downstream processes in other systems are failing due to multisurface /curve polygons.
I have tried exposing the fme_type and geometry, but they are always “fme_areas”. However, if I run GDAL ogrinfo tool identifies lots of Multisurfaces, some are also CURVEPOLYGONs. For example, GDB today with 8 records had 64 multisurfaces.
Any anyone help point me in the right direction for how I might Id these issues in FME, or incorporate the GDAL tool somehow?
Note: I cannot share example data due to its sensitive nature.
Many thanks
  • Sep 24, 2025 5:19 AM UTC
Hi ​@krio ,
You can use AggregateFilter to detect Aggregate (including Multi) geometries.
However, regarding CURVEPOLYGON whose boundary contains non-linear curves e.g. arcs, I don't think there is a transformer to detect that. A possible way is to perform a Python FME Objects API fmeobjects.FMEArea.isBoundaryLinear method with PythonCaller.
krio
  • Sep 24, 2025 6:23 AM UTC
Thank you, Takashi.
The AggregateFilter did not detect any aggregate geoms.
I have not used PythonCaller before, but I will give it a try.
Thanks again
Forum|alt.badge.img+54
  • Sep 24, 2025 8:00 AM UTC
Something similar here
evieatsafe
Forum|alt.badge.img+28
  • Oct 1, 2025 4:16 PM UTC
Hi ​@krio thanks for your question. I think you may need to test for arcs, these often cause issues. Some suggestions below:
  • if you want to convert the arcs before writing, the ArcStroker could help you
  • if you are trying to filter all geometries that contain arcs (without stroking them), the GeometryPartExtractor may be helpful to filter. You can specify "a child of this part has a Geometry Type of IFMEArc." in your XQuery. “extracted” port would have your arcs
If these suggestions don’t help, perhaps you could provide some sample data to test the logic and investigate further. Happy FMEing!
krio
  • Oct 7, 2025 7:59 AM UTC
Thank you so much everyone! I really appreciate the support and expertise from this community.
I have played around with PythonCaller as per the example that ​@ebygomm linked, but was not getting the expected outputs. However it does seem a very powerful tool to get to grips with, so I shall keep working with it.
In the short term, the arcs were picked up (at least in this particular data example I have) with the GeometryPartExtractor transformer. I will build in some complexity to the workbench and example data to road test it further. Thanks ​@evieatsafe!
s.jager
Forum|alt.badge.img+27
  • Oct 7, 2025 8:15 AM UTC
Not tested, but you could try the  GeometryExtractor. Extract the geometry to WKT (without removing the geometry), then test for the different geometry types in the WKT-attribute (Attribute Contains CURVEPOLYGON, for example). Afterwards you can remove the WKT-attribute again, to prevent a lot of unnecessary memory-usage.
Might be an option? Haven’t tried this myself yet, but I think I’ll try it for a similar case I have.
