I have converted a large geoJson into cesium 3d tiles -- wonderful... but not when enabling terrain -- tiles are partially visible obviously due to elevation. Is there something available in FME to consider the terrain?
  • Oct 7, 2021 4:05 PM UTC
  • 81 views
itsmatt
Forum|alt.badge.img+48
  • Oct 8, 2021 10:57 AM UTC
(assuming the GeoJSON features are flat/2D) You can try and drape the GeoJSON features over the terrain, however, this means you will need access to the terrian in a format which FME can read (e.g., GeoTIFF). It's also likely that there will still be issues where the draping doesn't overlap perfectly but it might give a better result than what you have now.
