I have an excel file of pipe CCTV record pdfs hyperlinks. The pdfs are stored in Google Drive and I want to be able to download these in bulk to a local folder.
  • August 11, 2022
  • 46 views
lferg
I have tried using the excel reader to get my file in, then httpcaller with the URL as my column of google drive shared hyperlinks. Renaming the output to a column which identifies the name that I want. I'm obviously not getting the settings right in the httpcaller or missing something entirely. New to using this and really no idea what I should be doing. For now I have only focussed on trying to download the Report but ultimately there is also a video avi to be downloaded. My input excel file looks like the following: Newname for the report and then the report google drive hyperlink.
Best answer by nampreetatsafe
Have you tried using the GoogleDriveConnector? There's an Object ID parameter that you can actually set by parsing out the Object ID from your URLs. I've put together a quick workspace demonstrating this. The URL I have there is a public URL which you can use. You will just need to update the Web Connection to your own Google Drive connection and download folder. Hope this helps!
nampreetatsafe
Forum|alt.badge.img+13
  • August 12, 2022
lferg
  • August 14, 2022
Thanks Nampreet that works great for the download. I had tried the GoogleDriveConnector but obviously didn't get the input values correct. Now trying to figure out how to get the downloaded file renamed.
I have followed a previous answer of Takahi's in the post https://community.safe.com/s/question/0D54Q000080hKw8SAE/quick-way-too-rename-files-for-noobs with a PATH reader and FILECOPY writer which allows me to put in a standard prefix or suffix. Found that reading in my excel file and joining with DATABASEJOINER works a treat.
