I have a *.LAS file, I want to transform it to ASCII ....file which contains the coordinates of the points, organised in one line per point. The coordinates are separated per spaces or tabs. Any thoughts?
  • Sep 11, 2017 7:26 PM UTC
  • 15 replies
  • 295 views
steveatsafe
Forum|alt.badge.img+16
Source(LAS)>PointCloudCoercer (Individual Points)>CoordinateExtractor>StringConcatenator(attribute named text_line_data)>TextLine Writer
  • Sep 11, 2017 7:35 PM UTC
thanks
will try it an see
steveatsafe
thanks
will try it an see
Make sure to add the PointCloudCoercer - I missed that on my initial reply.
steveatsafe
thanks
will try it an see
And depending on the size of your point cloud - you may be creating millions of points...
  • Sep 11, 2017 7:42 PM UTC
so, not ASCII writer?
  • Sep 11, 2017 7:44 PM UTC
yes
it is really big
it is almost 12 million points!!
erik_jan
Forum|alt.badge.img+26
  • Sep 11, 2017 7:45 PM UTC
Have you looked at the Pointcloud XYZ writer?
  • Sep 11, 2017 7:51 PM UTC
where should it be placed between?
steveatsafe
What do you want to achieve?
  • Sep 11, 2017 8:34 PM UTC
a bit complicated
transform my *.LAS file into an ASCII file (like the one attached)cube.pdf ... to open it in a software called DSE to extract discontinuities from a rock face...
  • Sep 11, 2017 8:57 PM UTC
yes
I tried it
and it successfully worked...however I need the final file format in ASCII
erik_jan
  • Sep 11, 2017 9:50 PM UTC
yes
I tried it
Yo can set the Character encoding in the parameters.
The output will be a text file (with default extension xyz).
steveatsafe
You could add the PointCloudThinner in before the Coercer... or you might want to look at thinning the points afterwards...
  • Sep 12, 2017 2:57 PM UTC
lidar-points-to-dfn.pdf
successuflly run..however, for some reason it resulted 4,051,966 rows !!
  • Sep 12, 2017 3:03 PM UTC
and this is how the inspector looks like...I did a mistake somewhere...all the data in one column!!!
inspector.pdf
Can you please advise where is my mistake?
