I have a dbf File I want to open into FME Desktop. I can read only the half of the records of the file which is bellow 2G.
  • Oct 19, 2023 4:08 PM UTC
  • 71 views
I put the link of the data I try here which is open data from the Quebec Governement Rôles d'évaluation foncière du Québec - Rôles d'évaluation foncière du Québec géoréférencés 2013 - Données Québec (donneesquebec.ca)
The problem table is B05V_UNITE_EVALN.dbf . When I open it in ArcGIS Pro, I can see 3000000 + records but in FME I see only 1500000.
  • Oct 22, 2023 9:20 AM UTC
Hi @geo_quebec​ ,
I was able to reproduce the problem.
ArcGIS Pro reads 3,444,793 records from the dbf dataset, but FME DBASE Reader reads only 1,477,769.
I think you'd better to ask Safe support.
@danatsafe​ , could you please take a look at this?
ArcGIS Pro
arcgis-proFME DBASE Reader
fme-dbase-reader
DanAtSafe
Forum|alt.badge.img+23
  • Oct 24, 2023 6:50 PM UTC
Hi @geo_quebec​ ,
ArcGIS Pro
fme-dbase-reader
Hi @geo_quebec​ FYI - I've now filed FMEENGINE-80797 about this problem. The DBASE reader seems to stop when it encounters several rows where all values are NULL.
  • Oct 24, 2023 7:57 PM UTC
Thank you, but I just checked the data with ArcGIS Pro and every row contain at least a column fill.
