Polygon feature must have at least 4 coordinates to be valid for the shape file. The feature will be skipped
REJECTING BELOW FEATURE:
And i dont understand what is really the problem
Can you help me please
thanks
A area with just 3 vertices was offered to the shapefile writer.
AS a correct polygon has first = last vertex.
You can check "the below" feature's vertices.
Either filter it out by: vertexcount =<4 and geotype = fme_area.
Or look at it in the feature information window.
Also, mostly after the run, the offending feature is saved in a ffs. It's code can be seen in the Translationlog. You can find it in your fme temp folder.
Maybe some othe features were not as closed as assumed
(in autocad the close function is safer then trying to snap the last vertex.
Fme ruthlessly exposes such errant assumpiotns....;)
