HTTPCaller help with POST
  • Aug 24, 2017 5:09 PM UTC
  • 149 views
cwarren
I've still learning how to use the HTTP Caller and wanted to see if what I'm attempting to do would be possible. I believe I need to use the POST method to pick the parameters and also upload the file. There is no API for this site unfortunately. I'm just not quite sure how to configure the HTTP Caller. Any help would be greatly appreciated!
Website: https://www.ngs.noaa.gov/OPUS/
HTTP Request I captured after manually submitting from the site
Best answer by mark2atsafe
I don't have a lot of information to guide me, but I think you'll want to set the Upload Data part to Multipart/Form Data, since that's what their page contents state. If your data is stored in an attribute then you could use Specify Upload Body - I'm getting that information from this question: https://knowledge.safe.com/questions/28528/httpcaller-file-post.html - but I don't know if the web page you are writing to supports that.
I'm going to guess that each part of the form needs to be a separate line in the multi-part table in the HTTPCaller parameters. Alternatively construct it all in a single attribute, as this example suggests: https://knowledge.safe.com/articles/23297/boxcom-3-upload-a-file-to-a-directory.html
My other suggestion is to turn on Debug Logging (Tools > FME Options > Translation) as when you do this you get a lot more information in the log about exactly what the HTTPCaller is doing.
I hope this gets you going in the right direction. Apologies if not, I'm just trying to pull information from the extra sources at my disposal. If you're still having problems let us know and I can pass on the question to someone in our web/server team.
mark2atsafe
Forum|alt.badge.img+59
  • Aug 25, 2017 8:39 PM UTC
cwarren
  • Aug 28, 2017 3:22 PM UTC
Thank you @Mark2AtSafe ! I will definitely look over those articles and see what I can figure out. Thanks again.
