How use the legacy SDE writer with versioning and archive tables
  • Mar 29, 2016 2:52 PM UTC
  • 64 views
Is there a parameter that needs to be set or a specific trick to getting the legacy ESRI sde writer to update archive tables when inserting records?
The current setup is as follows
A direct connection to an ArcGIS v10 geodatabase in an oracle 11g database, writing directly to the DEFAULT database version. The schema for the feature class is derived from a workspace resource pointing at the same sde database with the same connection details
This correctly updates the Adds tables for the versioned feature clases but no records are inserted into the archive tables. Is this just a product limitation, a bug or am I missing something?
I can get the archive tables to update correctly when using the ESRI Geodatabase writer, but want to avoid this due to the ArcGIS license requirements and the performance benefits of the legacy writer.
fmelizard
Forum|alt.badge.img+22
  • Mar 29, 2016 11:51 PM UTC
Hi David,
This won't be possible using the legacy Esri SDE writer. That writer won't know anything about the archive tables as they are part of the Geodatabase model. It may be possible to write to them as "regular" feature types, adding additional field values as required to maintain the archiving information. But we haven't tried that ourselves so you would be off in uncharted territory if you tried it.
We recommend using the Esri Geodatabase writer for accurately maintaining your archive tables.
Regards,
Robyn
