How to write several DXF OR DWG files after coordinate transformation from one input directory into another output directory?
  • Mar 21, 2017 4:53 PM UTC
  • 5 replies
  • 181 views
I would like to transform a directory with several DXF oder DWG files with a coordinate transformation and write all the DXF or DWG files into one new directory. How can I write all the files with the same schema as the input files? I need an output file per input file. I only get one merged output file from the input files. I tried to do that with dynamic reader and writer. How can I get the same amount with same schema of output files like the input files? With esri shapefile this ist easily possible with dynamic workflow.
Thank you!
Best answer by erik_jan
Look for the setting "Fanaout Dataset" on the Writer.
Use the attribute fme_basename as the Fanout attribute (it contains the name of the file from the Reader).
That allows you to create the same files in a different folder on the output.
erik_jan
Forum|alt.badge.img+26
  • Mar 21, 2017 5:03 PM UTC
itay
Forum|alt.badge.img+19
  • Mar 21, 2017 6:12 PM UTC
Dynamic is the way to go for this job, but as @erik_jan mentions, the dynamic transformation will use the fme_feature_type ( in cad terms layer or level), what you need is the fme_basename (file name).
  • Mar 23, 2017 1:00 PM UTC
Thank you for the suggestion.
I made a AttributeExposer with Attribute to Expose: fme_basename. I tried to set the writer but it's not working yet.
How can I configurate the writer that I get the dxf files?
itay
  • Mar 23, 2017 1:15 PM UTC
I think that this is a good place to start when trying a dynamic translation:
https://knowledge.safe.com/articles/1050/dynamic-workflow-tutorial-introduction.html
And in your case this I would recommend this too:
https://knowledge.safe.com/articles/1157/dynamic-workflow-tutorial-destination-schema-as-a.html
just mind the difference between the GIS example and your CAN data , especially the difference between the fme_basename and fme_feature_type
https://docs.safe.com/fme/html/FME_Desktop_Documentation/FME_Workbench/!FeatureTypeProperties/feature_types_attributes.htm?Highlight=basename#About2
  • Jul 6, 2017 2:56 PM UTC
thank you @itay, unfotunately this is not helping for my problem. I made a new attempt for solving it because it would be very helpful for several workflows.
I follow the steps like in the tutorial "Dynamic Workflows: Destination Schema as a Mirror Image of the Source Dataset " described, but there is no automaticlly published Parameter called 'Feature Types to Read'.
I can write shapefile data dynamically in a new folder and the difference with the feature type to CAD data is clear but I can't implement it for the CAD data. I need something like a feature type fanout in the writer from the feature type, but I don't know how.
Can someone help me?
