How to write separate single part shapefiles rather than one multipart shapefile?
  • May 12, 2014 6:00 PM UTC
  • 61 views
makt
I have a workspace that writes out one multipart shapefile (many rows in the dbf).
I'm looking to instead write out separate shapefiles that would correspond to each part (i.e. one shapefile for each row in the the multipart shapefile).
Not sure if my workspace requires additional transformer(s), modifying the writer parameter settings, or would involve both transformers and writer parameter settings.
I tryed experimenting with fanout settings in the the writer, but I haven't got anything to work.
Best answer by fmelizard
Have a look at the Deaggregator, to decompose your geometry.
fmelizard
Forum|alt.badge.img+22
  • May 12, 2014 6:20 PM UTC
  • May 12, 2014 6:46 PM UTC
Can you send a image of your Attribute table?
makt
  • May 12, 2014 7:34 PM UTC
ETLS-Itay - your hint was enough thanks
