I've put a autocad template file with two test blocks, a Shapefile with points and a FMW-file in a . So I hope you can seen whats going wrong. I tried to export point features to blocks with autocad_od writer because I want to save other data as Object data. This does not work! When I use de realdwg writer it is still working right.
What is wrong in the Autocad_od writer parameters?
