How to write byte[] in json to PNG image
  • February 15, 2018
  • 169 views
A JSON file stored PNG images in byte[] text format. How do I convert them into PNG?
lottegis
  • February 15, 2018
I'm guessing the byte data type is base64. If that's the case, try...
  1. BinaryDecoder: Encoding Type=Base64
  2. RasterExtractor: Format=PNG
I think this article is related, that you can go in reverse: https://knowledge.safe.com/articles/1176/embedding-images-in-html-with-fme.html
jochgem
Forum|alt.badge.img+4
  • July 11, 2018
A small correction: the RasterExtractor needs to be the RasterReplacer. The two steps explained are correct.
