How to write byte[] in json to PNG image
  • Feb 15, 2018 10:23 PM UTC
  • 248 views
A JSON file stored PNG images in byte[] text format. How do I convert them into PNG?
lottegis
  • Feb 15, 2018 11:48 PM UTC
I'm guessing the byte data type is base64. If that's the case, try...
  1. BinaryDecoder: Encoding Type=Base64
  2. RasterExtractor: Format=PNG
I think this article is related, that you can go in reverse: https://knowledge.safe.com/articles/1176/embedding-images-in-html-with-fme.html
jochgem
  • Jul 11, 2018 12:00 PM UTC
A small correction: the RasterExtractor needs to be the RasterReplacer. The two steps explained are correct.
