How to write an IfcSite with correct placement ?
  • Nov 18, 2019 5:55 PM UTC
  • 158 views
Hello,
I used FME Workbench 2017 to generate an IfcSpaces from shape file with footprint polygon and height information. I managed to create space geometry but I could not create longitude and latitude for IfcSite. These values were empty ($). Is there a way to fill theses values with FME Workbench 2009 ? Knowing that today I use a not very powerful method which consist in replacing the text of the end line of IfcSite definition : .ELEMENT.,$,$,$,$,$) by another one with right values : .ELEMENT.,(42,45,2,206849),(0,-25,-12,-380875),0.,$,$)
Or perhaps is there a way to write ifc_object_placement for IfcSite which could be another solution to have correct placement ??
Thank you in advance for your help
Best regards
Bruno
Best answer by daveatsafe
Hi @brunohilaire,
Please try setting the RefLatitude, RefLongitude and RefAltitude attributes on the site feature in FME 2019.1 or higher.
You can get the latest version of FME 2019 from www.safe.com/download.
daveatsafe
Forum|alt.badge.img+24
  • Nov 20, 2019 11:52 PM UTC
Hi @brunohilaire,
Hi Dave,
Thank you very much, it works well with the 2019.2 version :-)))
Bruno
