How to use the ArcGIS python library in FME?
  • October 19, 2018
  • 197 views
martinkoch
Forum|alt.badge.img+22
Hello all,
I want to use the ArcGIS api from PythonCallers in FME, and do that on server.
https://developers.arcgis.com/python/guide/install-and-set-up/
All works fine on desktop, when I switch to the ArcGIS Pro python.
When I install the library, and its dependencies in my Documents/FME/Plugins/Python/python36, and use the Default Python 3.6 for my workspace, I get a message
Python Exception <ImportError>: dateutil 2.5.0 is the minimum required version
When I do
import fme
import fmeobjects
import dateutil
def processFeature(feature):
    logger = fmeobjects.FMELogFile()
    logger.logMessageString("dateutil is version {}".format(dateutil.__version__))
I get
dateutil is version 2.4.0
Even when I have added the dateutil 2.7.3 package to my plugins/Python/python36 folder. It seems I can't override the dateutil-version and therefore not use the arcgis library.
I do not intend to install ArcGIS Pro on our server, as of licencing, overhead, and I want this to run on FME Cloud as well, which is Linux based.
Hope someone can help.
Kind regards,
Martin
