As you can see below, I have a simple DWG to Shapefile workbench going. But every time I need to add a new CAD layer to be read, I need to add a new reader, so I end up with multiple readers reading the same DWG as seen below:
How do I make it so I can simply add a new CAD layer to be read from the same DWG without having to stack up multiple reduntant readers like this each containing a couple of layers from the same drawing?
Is there a setting that will allow me to alter it like I can with writers for example, as seen below?
