How to tell the Esri writer to only update attributes and not geometry
  • Sep 19, 2017 5:11 PM UTC
  • 5 replies
  • 234 views
dnguye1
Participant
I am using Update write to do updates to a version in esri geodatabase and wonder how to I tell the writer to only update attributes and not geometry. Has anyone done something similar? Thanks!
Best answer by fmelizard
Hi @dnguye1, can you try removing the geometry with the GeometryRemover prior to write?
courtney_m
Forum|alt.badge.img+23
  • Sep 19, 2017 5:23 PM UTC
If you use the UpdateDetector transformer, you can specify whether or not to match geometry - just set Match Geometry to "None".
steveatsafe
Forum|alt.badge.img+16
To confirm dnguye1 doesn't want to update the existing geometry in the geodatabase table... just the attributes. He's also not able to use the underlying database's format (for ex. Oracle) to do the update due to IT restrictions. Can the Geodatabase SDE Writer only pass non spatial attributes and only affect the non spatial attributes when doing an update?
dnguye1
Participant
  • Participant
  • Sep 19, 2017 6:43 PM UTC
Courtney, thanks for your responses. However, what I am looking for is a way to tell the Update writer not to update geometry from a coming stream of data that has attributes and geometry. UpdateDetector does the comparison only I believe.
fmelizard
Forum|alt.badge.img+22
  • Sep 19, 2017 10:30 PM UTC
dnguye1
Participant
  • Participant
  • Sep 20, 2017 2:40 PM UTC
Thanks Tia. GeometryRemover works perfectly in this case!
