How to store a select result in a constant
  • Jan 14, 2019 3:13 PM UTC
  • 49 views
I'm new on FME and want to know if is there a way to store an oracle select as constant? This value will be used to update some oracle tables.
erik_jan
Forum|alt.badge.img+26
  • Jan 14, 2019 3:36 PM UTC
This question is not really clear.
Can you give an example of what you mean?
gio
Forum|alt.badge.img+15
  • Jan 14, 2019 3:51 PM UTC
Do you want to store the statement or part of it and use it in a SQL-Creator/Executor?
You can simply create the statement or part of it (or an entire query) in a attribute.
Assemble your query in the SQL-Creator/Executor using the previously created attribute(s).
(basically a "pseudo dynamic query" using fme. Much easier then true dynamic query using oracle)
Just be aware that you cannot populate with pseudo dynamic queries. ( you will have to use a non dynamic to populate (a simple select * will do) it and then replace the query with the dynamic version).
But if you want to store a select statement or part of it, and access this using oracle sql, you can if you store it in excel/txt and then access the excel/txt trough oracle.
