How to split one shape file into multiple shape files, each from one row?
  • Aug 2, 2016 12:59 PM UTC
  • 423 views
aguan
Forum|alt.badge.img+11
I have a polygon shape file containing a few dozens of rows. How can I split the shape file into many shape files, each containing only one row?
Best answer by redgeographics
In the writer feature type parameters you can set the shapefile name, if you select an attribute there it will make a new shapefile for each unique value of that attribute, so if you have an attribute with a unique identifyer it'll create one shapefile per feature (and if you don't have such an attribute you can use the Counter to create it.
So here for example I've picked the attribute "id" as my shapefile name.
Hope this helps.
Forum|alt.badge.img+63
Hope this helps.
