How to SELECT all records with Point geometry?
  • Dec 5, 2024 3:17 AM UTC
  • 120 views
nicholas
Forum|alt.badge.img+14
Hello all,
I have an Oracle Spatial table that contains some records with a Point geometry and some records with a Polygon geometry.
Considering the large number of records, I would like to take advantage of the ability of the Oracle Spatial Reader to perform a SELECT within the Oracle database and return only records with a Point geometry
(This is preferable to Reading all records and then using a GeometryFilter for performance reasons)
How to I write the SELECT statement?
I assume it has something to do with SDO_GEOMETRY, but I just cannot get the syntax correct
philipwhitten
Forum|alt.badge.img+15
I haven’t used oracle, but from https://docs.oracle.com/database/121/SPATL/point.htm#SPATL529 it looks like:
      WHERE table_alias.field_name.SDO_GTYPE=2001 (e.g. WHERE c.shape.SDO_GTYPE=2001).
Something like this should work for a 2 dimensional single point.
nicholas
  • Dec 5, 2024 4:28 AM UTC
I get an “invalid identifier” error
geomancer
Forum|alt.badge.img+71
  • Dec 5, 2024 6:40 AM UTC
Use SQLCreator (instead of the Oracle Spatial Reader) to read data with a SQL command on geometry.
select * from YOUR_TABLE t where t.YOUR_GEOMETRY_COLUMN.sdo_gtype = 2001
Enter your own values for YOUR_TABLE and YOUR_GEOMETRY_COLUMN.
